500bhp requirements
  • Rob_
    • Jan 2009
    • 13
    500bhp requirements
    Can anyone give me the lowdown on what parts are required to reach around 500bhp
    GT35r
    Intercooler - What do people use? Is RS2 sufficient or what alternatives are there
    What about downpipe?
    Injectors?
    What do people do about management can you get the audi ecu remapped or do you have to go standalone?
    Will the diff cope?
  • lind4hl
    • Jul 2008
    • 2465
    the diff would fix it, no problem
    i think that the wagner intercooler would work great for 500 hp.
    a good company in england are mrc, but vems has an plug and play box for our cars
    a 76mm (3") downpipe should also work great
    • K7ERG
      • 1711
      Steel rods
      EM
      Audi A6 AEL 5cyl Quattro breaking.
      Audi A5 3.0tdi Quattro Stage 2
      07947385043
      • Rob_
        • Jan 2009
        • 13
        Originally posted by K17ERG
        Steel rods
        EM
        Would you just fit new piston rings as you have to remove the pistons to fit the rods?
        Standard pistons ok then
        • K7ERG
          • 1711
          Yep depends on how much power you are loking for.
          GT3076R with 0.82 housing will see 500
          07947385043
          • Rob_
            • Jan 2009
            • 13
            Is the standard wastegate up to the job running the higher boost or is a 44mm one required?
            • lind4hl
              • Jul 2008
              • 2465
              i have seen high boosted 700bhp with standard wg, it depends on how much boos tyou will use, high boost = smaller wg is needed, because less exhaust that you need to take through the wastegate
              edit: i think original is 38mm if i not remember wrong.
              • Rob_
                • Jan 2009
                • 13
                Are you sure.Ive always heard running higher boost requires a larger wastegagte because a smaller one cannot release the gas quick enough meaning you get really bad boost spikes
                • URSIMPO
                  • Jul 2008
                  • 431
                  What hp will a gt3076 .63 exhaust housing give, and would a tubular manifold flow better giving lower EGT's
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    I have a GT35 for sale if you want 500hp this will do it
                    Chef
                      About 480 with a tube manifold
