blinkin eck
  • l455lnk
    • Oct 2006
    • 6
    blinkin eck
    advice please gentlemen
    94 aby s2
    109000 miles
    heavy misfire under hard acceleration
    blink code 2121
    i think the code descriptions can be very woolly and misleading. I recently had another code which directed me in completely the wrong direction, indicating a cam position sensor, and it was thanks to mr murray pointing me in the right direction that the air mass flow meter was replaced and all was well.
    what would you look at first?
    cheers
    paul
  • denniselbows
    • 740
    if the 2121 blink code is the same as on the 3b then it is the idle switch in the throttle position sensor make sure it clicks when the throttle is closed if the blink codes are different on the aby then forget the above
    never set your expectations to high that way you are never disapointed
    • Tonks4x4
      • Nov 2005
      • 3062
      Do a quick boost leak test aswell to rule out that as a possible cause.
      Audi Nut!!!
