as the heading. What is the power level standard valve springs can handle? Before having to change them for different ones. Also where to buy new standard valve springs?
what power levels can the standard valve springs handle?
The spring has is not effected by power--heat and speed are what kill springs the springs only close the valve, the cam would take all the load of opening a valve under pressure, the spring is just there to shut it againEverything should be made as simple as possible, but not simpler.--:Albert EinsteinComment
Lighter lifters and lighter retainers can extend the possible rev range of the springs.
Using stiffer springs with stock rev limit (and not too radical cams) is a complete waste of money that will cost horsepower and accelerate cam wear.
You want the softest spring that will not float the valve at redline. Anything stiffer will cost horsepower at all rpms.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
ExactlyLighter lifters and lighter retainers can extend the possible rev range of the springs.
Springs are more of a concern with higher lift cams as the higher the lift the more of a pounding they take.Comment
Agreed also... Nicely worded by Espen there
I know it may be better to ask this somewhere else but, as it all has relationship with head specs, I have decided to ask it here. I was wondering how much output can the standard valves handdle, and also how much power could be obtained using the stock head, without having to modify / polish ports and valve guides.
Thanks very much
Cheers!Audi Coupé S2 '92 -- VW Golf 2 GTI '91 (v2) -- Renault 4 TL '84 -- Audi 100 2,3E '92 (Dad's) -- Suzuki SV 650 S '08
Did you check your cam timing already? Your RR graph looks a bit different from what I would expect from a 7A cam setup with a GT35. Especially that dip just before the line starts climbing.Comment
Can you post the AFR graph too. I had the same sort of dip when running too rich. Superflow is a strict dyno, so 395whp isn't that bad, but 386nm is low for that setup.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
