3B ECU required for 10 minutes
  • Knight Rider S4
    • 3541
    Hi
    I have a spare ECU which I can lend you (standard settings) if you want to cover the cost of P+P
    Steve
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • 20Vcqdriver
      • 829
      Thanks for offer . Paul is now returning my original one that I know has worked before.
      Having found a tiny leak on the inlet manifold hoses that I didn't think would make any difference was amazed to see boost increase to 1.2bar. Still cuts out to limp mode after a few minutes though. MAF on order now too..
      1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
      2004 A4 2.5TDi convertible, re-mapped to 180bhp
      2011 A5 sportback 3TDi-Backbox delete, remap
        That puppy will boost to 1.4bar with a healthy ECU, good MAF and no air leaks !
        Your stock ECU isn't going to put anything like as much stress on the air hoses, but it will sure help us find out if that spare ECU is a lemon...
        • s_sport
          • 2
          • Home: Norway Current: United States
          any updates?
            #20
            Blown turbo seals diagnosed on this one... It was a recently refurb'd turbo too - must not have been done properly for some reason.
