Ok guys I am trying to take my kv engine out so I can replace it with a aby lump and gearbox, but as usual I am hitting a few walls.
Firstly, how does the starter motor come out, I have removed a visable bolt at the bottom, but its not moving.
Secondly how do you take the exhaust manifold off, I have removed all the top bolts and 3 of the lower ones closest to the front of the car but its the ones at the back I cant seem to get to?
Thirdly I have removed the drivers side suspension but cannot get it away from the steering rod, there is a ball joint coming off that piece sticking out of the shock body, how do you get that off?
Fourthly the moment i put the tool into the bolt on the prop it went round, short of going mad with an angle grinder, any ideas, also how do you disconnct the front section of the prop from the rear?
And I thought getting the engine out would be easy,,,, DOH!!!!
Any help on this would be great.
Cheers guys
Cheers guys
