Intake temperature
  • Intake temperature
    Hi everyone!
    Is there any possibility to get a reading of the intake temperatur using either VAG-COM or some special gauge/tool/equipment from the standard intake temp. sensor??
    Feels a bit unnecessary to buy an intake sensor and gauge just to see what difference the bigger IC will have.
    /Mike
    /Mike
    S2 RS Avant@355hp "For sale"
    A4 Avant TDIq@170hp
    Datsun 240Z@550hp
    BMW M3 race car@321hp
    Garage
    Sure is with VAG-COM - but not on a 3B engine !
    VAGCOM is more expensive than a temp guage though...
    Checkout http://S2central.net and follow links to TECHNICAL chapter then you'll see links to Engine or Diagnostic info - that lists all the data on the ABY and ADU engine which can be read with VAG-COM.
    VAG-COM will let you log this info to a PC file for analysis.
    Paul
      Blind as a bat??
      Ahhh thanx. I´ve got the VAG-COM but obviously have not taken the time to investigate the full potential of it Now I´m off to test intake temperatures
      tnx again
      /Mike
      /Mike
      A4 Avant TDIq@170hp
      Datsun 240Z@550hp
      Garage
