Nice alternative - comes with a carbon cover too!
How much for coil packs these days ?
I am posting this up here now, but will find a good home for it later...
Here is the cross reference from Beru for ALL parts they make for our cars.
I have enquired about the UK distributor and will see if we can get any deals going...
Beru Cross Reference
BERU AG : Products
Product finder
Your vehicle
Model Type Model year Power output Cc / Cyl.
Audi COUPE (89, 8B) S2 quattro 10.1992 - 12.1996 169 kW / 230 PS 2226 / 5
can be fitted with the following original BERU brand product(s):
Product Type Code designation Type designation Order No.
Lambda Sensor - OZH 027 - 0 824 010 028 1374
Catalytic Converter Type Without catalaysator
Tightening Torque [Nm] 45
Replace after km 100000
Thread Size M 18x1,5
Conductor Number 3
Cable Length [mm] 890
Lambda Sensor Heated
Lambda Sensor Regulating Probe
Lambda Sensor - OZH 037 - 0 824 010 039 1374
Conductor Number 3
Cable Length [mm] 880
Exhaust System In front of the catalyst
Coil, ignition - ZS 043 - 0 040 100 043 1374
Required quantity 5
Installation Information: Recommendation: Use grease for spark plug adaptors (ZKF 01 - reference No. 0 890 300 029), see accessories lists.
Technical Information: vehicles without distributor
Port Type SAE-Kontaktfeder
Ignition Coil Coupling Type SAE
Ignition Coil Incl. spark plug connector
For components see parts list
Rubber Sleeve, coil - ZLE 233 - 0 300 122 116 1374
Only in connection with 0890300029 / ZKF 01
Manufacturer Restriction 0040100043 / ZS 043
Length [mm] 122
Ignition Coil Coupling Type M4
Spark Plug Coupling Type SAE
Resistance [Ohm] 5000
Ignition Switch - ZM 063 - 0 040 401 063 1374
Bore Distance [mm] 55
Manufacturer Restriction System BOSCH
Sender Unit, oil temperature - ST 065 - 0 824 131 034 1374
Temperature Range [°C] max. 180
Tightening Torque [Nm] 12
Number of ports 1
Fitting Depth [mm] 9
Thread Size M 10x1
Spanner Size 13 mm
Oil Pressure Switch - SPR 017 - 0 824 331 034 1374
Technical Information: Product installed must be determined on vehicle or engine.
Tightening Torque [Nm] 30
Colour Coding Grey
Number of ports 1
Thread Size M 10x1
Spanner Size 24 mm
Switch Pressure [bar] 1,7-1,9
Oil Pressure Switch - SPR 021 - 0 824 331 037 1374
Colour Coding Grey
Number of ports 1
Fitting Depth [mm] 13
Thread Size M 10x1
Spanner Size 24 mm
Switch Pressure [bar] 1,3-1,5
Regulator, alternator - GER 012 - 0 190 005 012 1374
For use in vehicles with alternator charge rate [A] 110
To Model Year 07.1993
Mounting Diameter [mm] 14
Voltage [V] 14.5
Manufacturer Restriction BOSCH
Coolant Temperature Sensor - ST 060 - 0 824 121 108 1374
Tightening Torque [Nm] 24
Number of ports 2
Fitting Depth [mm] 17
Thread Size M 14x1,5
Spanner Size 19 mm
Aerial - A 110 S - 0 460 400 110 1374
Fitting Position Dacheinbau
Cable Length [mm] 440
Operating Mode Electronic
Bulb, stop light - 312 210 - 0 500 312 210 1374
Socket Version BA 15 s
Bulb Type P21W
Rated Capacity [W] 21
Voltage [V] 12
Bulb, spotlight - 112 557 - 0 500 112 557 1374
Socket Version P 14,5 s
Rated Capacity [W] 55
Voltage [V] 12
Bulb Type H1
Bulb, headlight - 112 565 - 0 500 112 565 1374
Replace in pairs only
Socket Version P 43 t
Bulb Type H4
Rated Capacity [W] 60/55
Voltage [V] 12
Bulb, headlight - 112 600 - 0 500 112 600 1374
Socket Version P 473 t
Voltage [V] 12
Bulb Type H4
Bulb, interior light - 412 100 - 0 500 412 100 1374
Socket Version S 8,5
Rated Capacity [W] 10
Voltage [V] 12
Bulb, licence plate light - 512 040 - 0 500 512 040 1374
Socket Version BA 9 s
Rated Capacity [W] 4
Voltage [V] 12
Bulb, fog light - 112 551 - 0 500 112 551 1374
Socket Version PK 22 s
Voltage [V] 12
Bulb Type H3
Bulb, fog light - 112 992 - 0 500 112 992 1374
Rated Capacity [W] 100
Voltage [V] 12
Bulb Type H3
Special Purpose Vehicle For special-purpose vehicles
Bulb, rear fog light - 312 210 - 0 500 312 210 1374
Bulb Type P21W
Voltage [V] 12
Bulb, parklight - 512 040 - 0 500 512 040 1374
Voltage [V] 12
Bulb, reverse light - 312 210 - 0 500 312 210 1374
Bulb Type P21W
Voltage [V] 12
Bulb, taillight - 312 050 - 0 500 312 050 1374
Voltage [V] 12
All information subject to change
By quoting this information, you will obtain the appropriate BERU brand products for your car from specialist retailers. We should point out that this service cannot replace the expert advice given by your retailer. Click the respective product to view more detailed information.
I need Information about »Where to buy?«
Back to manufacturer listThe Perfectionist
Mmmmmmmmm - nice looking plug and play - and carbon always looks cool, but I'm just not convinced about longevity of the 1.8T style coilpack. That and the scarey Eurolad price !Paul Nugent
LS2 coilpacks not an option, got 6 coils and 6 harnesses for £150 delivered to my door.
Or is it OEM all the way.Carlos.
On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.ukComment
I'll stick as much info as i can find in my project thread...nearly bedtime...
Carlos.
I am also looking for new ones.
I have seen these.
Good price i think ,but will it work 100% ok?
http://cgi.ebay.de/ws/eBayISAPI.dll?...m=160292594084Comment
Do tell me more - are these the ones that UrS4boy was raving about ?
If they are higher spec than 1.8T items and can live happily under the metal cam cover, then for that price its tempting alright... Even if they only last ~30k miles they will pay for themselves versus the big buck Beru coils.Paul Nugent
SCratch that idea - had to be too good to be true... Did a quick search here and LS2 coils are coil 'near' plug - so require HT leads from a bulkhead location - not for me...Paul Nugent
1994 Audi S2 Avant - in pieces
2006 Skoda Octavia vRS 2.0TFSi - goes fast
1985 Audi 90 quattro - is wet
Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]Comment
I have been contacted by the local Beru Distributor, I will let you all know how I get on with pricing!The Perfectionist
