Ecu
  • jade
    • Jan 2005
    • 1811
    Ecu
    ECU Pin 38 Coding Plug (where applicable) can anyone tell me what this dose, some thing to do with alarm ???
    Thanks
    RS 2 580HP
    It is used on RS2 for example to act a speed limiter when the plug is connected. Not used on 3B, AAN or ABY as best I can tell.
    • jade
      • Jan 2005
      • 1811
      I have been tracing my alarm wires and have found it is only a central lock unit by meta
      windows & doors, horn, lights
      Now i will have to find out what is acting as my immobilizer
      When looking for the Rpm signal for my zt-2, I found that someone had spliced into the cable & separated it at pin number 38 other end is switched here below ideas.
      Regards
      RS 2 580HP
      • jade
        • Jan 2005
        • 1811
        So has some one put a switch in for speed limiter ???
        RS 2 580HP
          Send me a PM - with exact model and year info - there are some cars which might use this for immo.
