You can fit liners to the 5cyl lump. I know of someone who has an RS2 motor with 1 bore sleeved. If you do go this way and get it sleeved, it's best to go for a captive sleeve that sits on a lip at the bottom of the bore, rather than a top-hat type that sits on the block-to-head surface. I've heard of these cracking the lip and allowing the liner to drop into the sump end of the block...ouch!
I'd have to agree with Lee, it would be a bad idea to go for sleeves on a high HP motor. Just get another block and have it bored out and honed with a torque plate, mains caps fitted, and the block heated to 90 degrees. In the end this could be far cheaper than rebuilding the whole lot again.
I'd get it clamped to a torque plate and have the bores accurately measured. You may find it's in tolerance.
