Not sure i understand these fuel pressure readings... fuel pressure gauge should be in FEED line to the fuel rail... the regulator keeps it at 4bar above manifold pressure and lets excess fuel back to the tank via return pipe.
At idle with 0.5bar VACUUM in manifold you should have 3.5bar fuel pressure.
At 1.5bar BOOST you should see 5.5bar fuel pressure
The wobbly boost guage isn't a big worry - either the spring is a bit too stiff for the ECU programming or vice versa... WGFV duty is being adapted by ECU to keep boost on target - quite a coarse thing.
