3B bottom end rebuild cost
  • 20Vcqdriver
    • 829
    Originally posted by goodall
    mb is k24, wr is k26, was one the changes to reduce lag
    however i dont think the mb has water cooling...
    MB/RR and 3B all same turbo, not sure if any differences made for the ABY K24 running higher boost with the overboost facility (uprated seals/bearings).
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
    • Rusty
      • 18953
      My mistake
      • Mikes2
        • 1704
        That's not correct.
        The MB is a K26.
        20v turbos use a K24
        Mike
        http://www.s2-audi.co.uk
        • 20Vcqdriver
          • 829
          Think you'll find only the WR used the K26, when the capacity was increased to 2226cc they also dropped to the K24 keeping the same BHP but improving the low speed torque noticeably.
          My poorly refurbed turbo now back with ITS Turbos, waiting to hear the excuses why it blew within 100 miles?!!
          • Mikes2
            • 1704
            Don't know why you think that.
            I've just removed the turbo from my MB and it's a K26.
            Mike
            • twoqu
              • Sep 2003
              • 3103
              #21
              Only the 10V MC 100 turbo had a K24!
              For some reason there does seem to be an issue using the K26 on the 20V apart from the relative unsuitability compared with the K24. The c/housings are the same so it is a bit of a mystery!
              • aelred
                • Jan 2005
                • 761
                MB turbo is KKK26 water cooled, WR is KKK26 oil cooled, S2's KKK24 watercooled. See other people comments also.
                Aelred
                • 20Vcqdriver
                  • 829
                  Looks like I got this wrong then. lucky I didn't use the mb turbo i was offerred then. Oops
                  Still waiting for a response from ITS Turbos.
                  Are the 3B and ABY turbos identical then? Or is ABY an uprated K24? Was told they are identical, is this corrector or is this info wrong too?
                  • Mikes2
                    • 1704
                    3b, RR, ABY turbos are the same.
                    The only difference would be the orientation with the RR version. The cold side can be loosened and rotated if being fitted in an S2.
                    Mike
