Leigh, probably taking you round in a circle on this one, but have you replaced/checked the hoses/clips inside the cab? I had a similar problems to you with the car not holding boost and it turned out to be a small leak from the vacuum tube just before it entered the ECU (more accurately the clip was very slightly loose.
Still got a ****** Boost Leak
Checked all those and replaced clips. I now have the ECU sitting in the passenger footwell and I can't here any leaks from it.Originally posted by blu_s2Leigh, probably taking you round in a circle on this one, but have you replaced/checked the hoses/clips inside the cab? I had a similar problems to you with the car not holding boost and it turned out to be a small leak from the vacuum tube just before it entered the ECU (more accurately the clip was very slightly loose.Ex 1994 Avant - now driving a Lotus 340r
