Can anyone tell me what pressure an ABY oil pump puts out? I need to get a replacement restrictor for my GT3071r and need to match the size of the hole in the restrictor to the oil pressure.
Need to get one this week as we're hopefully going to start the engine this weekend. Turbo Dynamics sell them but need to know what the oil pressure is to supply the correct one.
Just spoke to them again and what they need is the actual pressure as it hits the turbo. Has anyone tested the oil pressure at this point? Needs to be acurate as I run the risk of either starving or over supplying if the restrictor is wrong.
You'll find off the shelf are 0.030 to 0.040 in size for the Audi application
Garrett quote
An oil restrictor is recommended for optimal performance with ball bearing turbochargers. Oil pressure of 40 - 45 psi at maximum engine speed is recommended to prevent damage to the turbocharger’s internals. In order to achieve this pressure, a restrictor with a 0.040' orifice will normally suffice, but you should always verify the oil pressure entering the turbo after the restrictor in insure that the components are functioning properly.
Recommended oil feed is -3AN or -4AN line or hose/tubing with a similar ID. As always, use an oil filter that meets or exceeds the OEM specifications.
