garrett bb turbo balncing question
  • aronmatic2
    • 2129
    • Country: Hungary
    i installed my gt30r today. when i spin the wheel with my hand, i hear the turbine wheel touching sometimes the housing.
    anybody had the same thing before?
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
  • revoth
    • Sep 2005
    • 20
    Hi Aron,
    when the engine not runs the wheels can touch the housing. Under oil pressure (i.e. when the engine run) the ball bearing is in right fit. The bearing sit exactly in the middle. There is more clearance and is normally at all ball bearing turbos. The journal bearing turbos have not so much clearance.
    You can test the turbo. if the clearance of the wheels is under 1- max. 2mm the turbo is ok. Alternately you can check the housing. If you see anybody scratches in there the turbo failed.
    Marco
    sorry for my bad english.
    • aronmatic2
      • 2129
      • Country: Hungary
      Originally posted by revoth
      Hi Aron,
      Marco
      i try tomorrow. thanks
