Which OEM look Boost Gauge?
  • GazzaG60
    • 4133
    that looks like a cheap defi/hks copy.
    maybe an autometer nexus.
    beauty of the hks ones is that tyeb are only maybe 15mm thick so can be mounted in a sun visor.
    try a defi boostmeter BF in red for oem. i got the white and red. its also accurate too. they cost more though.
    boost and no vac is not really any good. its more a pressure device. even on an SC car its nice to see vac.
    • veneto rs2
      • Jun 2006
      • 1022
      • Country: Veneto
      #32
      For OEM best look of turbo gauge I believe a swap between voltmeter and turbogauge it's the best looking solution.
      My gauge was bought trough a group buy here on S2Forum sometime ago.
      http://www.audisportclub.com/
      • GazzaG60
        • 4133
        so how do you manage to go full throttle and look down there.
        ill answer it. you dont.
        can you honestly say you can give an accurate figure of boost.
        1. not being able to see it.
        2. it being at a poor angle for accurate vision.
        also no peak hold or record so no way of telling.
        • driftin jo
          • Sep 2007
          • 2222
          Or to sum up what you are saying in one word, “ useless ” .
          • veneto rs2
            • Jun 2006
            • 1022
            • Country: Veneto
            #35
            Well well.......
            To be very honest..... after driving Audi IL5Turbo 20V motors since 1992 (3B before and ADU after and still) I feel the proper boost with my "a**" rather then looking at a needle
            Also I believe anyone would rather give a peripheric look (glance?) at instruments like gauges and not staring at them... or not.?
            In any case if I really need to check the gauge because I feel something wrong....(and that it's the only moment when my eyes are searching for it....)
            Like i.e. Maximum boost and problems on getting it and/or keep it....
            Straight secondary road 5th gear full trhottle and I always had the chance to have a proper info.
            I agree with you thoug that in other cases (not my case..)you need that gauge to be in front of you or (better) the passenger (hence the centre location) if you want to proudly show the pressure you develope every time you shift gear....
            Stefano
            • GazzaG60
              • 4133
              if its for a look thing and not to be useful then yes.
              i didn't want to say useless Jo. im was trying to keep the 1 thread of diplomacy i have left in me after this mornings events for the forum. lol
              its useless and dangerous to be exact. people find it hard not to try to take a look.
              you must have a better ***-Dyno than me veneto. i like most would find it hard to see effective changes to boost hit and hold and ramp into boost.
              recording and peak hold are a must for me.
              i use
              in one of these [IMG]http://www.perrinperformance.com/shared/images/products/428/769_large.jpg[IMG]
              its a perrin racing universal. i have the previous version. fits perfectly on S2 cowling.
              not factory look though but money well spent for a USEFUL device.
              • veneto rs2
                • Jun 2006
                • 1022
                • Country: Veneto
                #37
                GazzaG60 nice one! I can see your point.
                Out of banter if there was one.....
                I believe it's all down on different motorist philosophy.
                In here we have very various approach on these lovely cars of ours.
                Some can streep down their to bare metal to gain that little bit of performance
                Some (not many) are very conservative on the OEM look of them to the last screw..
                Some (probably me in the bunch) are in between of these two categoryes, they want something out of their motors/cars but don't want to be "too intrusive" on them to keep the collectable value
                My answer was driven by the first issue/question on the thread title:Which OEM look Boost Gauge?
                So far I still believe that my solution (wich I copied from others anyway) it's the only one that matches 100% the question.
                Looking or glancing, how many times or never or randomly, it's not an issue in this case IMHO.
                If ,instead, we want to talk about: Wich one it's the best turbo gauge?
                Then the scenario can be far more various.... and I'll probably agree with you in many points.
                Stefano
                P.S.
                remember in any case that on LHD car that viewing angle it's not so bad.....
                • irishs2
                  • Apr 2009
                  • 2455
                  Sorry to derail this thread just a wee bit, but veneto, what model concert is that radio, and are you using a can bus emulator ?
                  Eric
                  95 S2 Avant under rebuild.
                  • veneto rs2
                    • Jun 2006
                    • 1022
                    • Country: Veneto
                    #39
                    It's a Concert 2.
                    For all the Beamish stout I had in your town I can give you for free this:
                    • GazzaG60
                      • 4133
                      you are correct veneto. its is the most oem as per title thread.
                      all im trying to say is in my opinion they are for sure form over function.
                      mine for most would be intrusive like you say. its easy to see from another "challenger" or from the car behind it isn't your standard audi. it ruins the fun a little. but so does the noise.
                      • GazzaG60
                        • 4133
                        does have the toys your car too per Irish comments.
                        • veneto rs2
                          • Jun 2006
                          • 1022
                          • Country: Veneto
                          #42
                          I'm not getting this....
                          Poor english must admit........
                          Don't understand if I have to laugh...
                          or start to chop a horse head for your night time.....
                          • GazzaG60
                            • 4133
                            sorry. its my poor english. not yours.
                            you have lots of good things on dash. radio, climate etc. all not common or possible here.
                            i have no AC, non factory radio. 2 working lit gauges down there. lol
                            horses head by fedex. bout 1k€. lol
                            • veneto rs2
                              • Jun 2006
                              • 1022
                              • Country: Veneto
                              #44
                              Got it now!.....
                              Sorry mods.....end of OT on my side.
                              Stefano
                              • carboRS2
                                • Apr 2011
                                • 105
                                • Country: Spain
                                #45
                                Originally posted by HPmuirt
                                The VDO is the closest that you will find but it should really be in bar like the Telemetrix one, however that has a white bezel so not as OEM looking.
                                The best option is this one, but with the €-£ exchange rate it will cost over double the standard VDO one
                                I ran 5 group buys for them for about 40+ folks on here who will agree that they are the best OEM fit. There are several threads from these group buys and loads of installed pictures so have a search and if you want one then I will put you in contact with the vendor and get you the group discount.
                                Cheers n
                                Si
                                P.S. Red 501 led bulbs are the best solution for the lighting
                                Hi everyone,
                                I'm in search of a turbo gauge for my car (RS2).
                                Reviewing the posts it seems this is the best solution.
                                I've tried to purchase one from www.s2fast.de but had no response from them.
                                Is this web still alive? Is there any group buy in the future?
