2.0 20v NM engine
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    2.0 20v NM engine
    hello friends
    i have the chance of buy for 300€ a complete NM engine with 216000kms, all of course ( cams,2000cc block,cylinder head.... ALL)
    i know that the nm cams will can able to some RS2 projects but can i do something with the cylinder head like the 7A head??? it is possible??
    and about the 2000cc block...will be able if install in it a 20vt head ??? i believe of course that it will need some work as the 2.5TDI stroker needs ....
    any coments or helps will be very apreciated
    -tomas-
    Cams are good, not sure about the rest. 300 euro for some NM cams is quite good ;-)
      Cams good rest scrap
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        300€ only for the cams are quite good??? ,i saw that they are very similar to the original ADU cams.... adu cams are very very expensive¡¡¡
        i will report this questions to Mister Peter Kowaksch... may he have to say something about cylinder head and block posibilities
        thanks Rusty and Jamo
          NM cams are rarer than Madonna & Angelina Jolie passing up the chance to adopt a child from a 3rd world country.........
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            good point Jamo
