Removing distributor drive from cam?
  • AndyP
    • 6049
    Has anybody tried to remove the metal drive gear from the 3B inlet cam? I have a damaged 3B cam and a good ABY one, so I need to remove the drive gear and from the 3B and refit it to the ABY cam. I've tried heat and a gear puller but it's not budging, is it pressed on or am I missing something?
  • volcano rs
    • Jun 2005
    • 2265
    its part of the cam and cannot be removed as far as i know.
    • AndyP
      • 6049
      It’s definitely not part of the cam, but then it’s definitely not coming off either, not with the equipment I have anyway
      Does anybody have a 3B inlet cam they want to sell?
      • goodall
        • Jul 2008
        • 810
        blow torch, heat the camshaft up and then try the puller
        or how about buying a gear? cant remember the name the place we got a gear from lately but they had a massive selection of stock gears
        • Acidburn
          • 13459
          It does come off but most of the time not by choice, there's been a few people on here that have had the gear just fall off whilst driving bending some valves in the process.
