034 engine mounts?
  • sjw185
    • 1175
    034 engine mounts?
    Anyone got any feedback on these mounts in street or track density?
    Also found threads about oem mounts and using uprated snub mount?
    Think I burst my offside one when changing out turbo
  • caterpillar
    • 2480
    use the street one,the track ones are for the track use( delring plastic or similar)
    • Flat on my back
      • Jan 2007
      • 2449
      Nope...
      Street mounts are made from a softer density rubber compared to the Track ones.
      I'm running Track engine mounts plus a snub mount, only notice it when you are stationary...only slight increase in vibes coming through.
      Carlos.
      • DJones
        • Jun 2005
        • 2020
        I'm also using track density, as you say only (slightly) noticeable at tick over. The gains in my view far out way any losses..
        • adamw
          • Dec 2005
          • 348
          • Country: Shetland Islands
          im using the 034 motorsport engine and gearbox mounts. i think thay are very good and only slight increase in vibrations at idle.
          cheers adam
          cheeRS adam
          RS2+
          • sjw185
            • 1175
            Thanks for the input
            Track ones could be ideal for me then as the s2 is mostly for fun driving and track days
            • A80Avant
              • 10873
              • Country: Greece
              i bought the street density ones to replace the OEMs next year.Car is used everyday,so i thought of going more casual!
              • stiglet
                • Aug 2007
                • 1264
                The motorsport ones are the solid ally/delrin. Don't get those unless you like noise.
                Get the track density ones. They are still rubber so will absorb most vibrations.
                • stevieyid
                  • Apr 2005
                  • 2251
                  Do those mounts in the first link fit an ABY S2 Coupe?
                  3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
                  • stevieyid
                    • Apr 2005
                    • 2251
                    sorry just relaised it says at the bottom will fit an ABY, so i have just answered my own question
                    • QuattroFever
                      • May 2006
                      • 1360
                      further to that tho will they fit an ABY with snigle mass flywheel??
                      Only one hole in the pic looks like you can slide it, are the original mounts like this with only one elongated hole??
                      Volcano ABY coupe
                      Ant
                        http://www.034motorsport.com/product...ducts_id=18578
                        Makes no odds, when going to single mass from dual the slack is taken up on the mounting brackets not the mounts themselves
                        • QuattroFever
                          • May 2006
                          • 1360
                          laaavly jaably.
                          Volcano ABY coupe
                          Ant
                          • MidnightBlueS2
                            • Jul 2005
                            • 1653
                            • Home: United States Current: Belgium
                            Ditto here. Never regretted fitting them to my ex-Avant
                            Midnight Blue S2 - SOLD - 1993 S2 Avant
                            • bambridge
                              • May 2009
                              • 609
                              Got some of the track ones (alum & delrin) if anybody needs some
                              pm me
                              Kev
