RS2 oil cooler - how to clean?
  • urS6
    • Dec 2007
    • 35
    • Country: South Africa
    Hi
    I have the front bumper off and I see that about 40% of the fin area of the oil cooler is like...well, solid oily sand/dust/mud? I am working on getting the plastic "funnel" off so I can get closer to it but once I can actually get in there - what is best way to clean it?
    Any tips apreciated
    Thanks
    1995 RS2 - old school handful ~ for fun!
    2004 allroad 2.7T now mine
    2008 GTi MkV DSG - was mine, now hers!
    1995 urS6(m) - sold
    Jozi, RSA
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    pressure water would do the job i guess
    • s2driveruk
      • 12696
      upholstery brush so should clear the grit but not damage the fins.....
      1992 3b S2 Coupe
      • urS6
        • Dec 2007
        • 35
        How 2 tips
        Thanx guys
        1995 urS6(m) - sold
        Jozi, RSA
        • dog_day_sunrise
          • Mar 2008
          • 23
          Would sand-blasting all the cack off it be likley to cause damage?
          • johne
            • Apr 2007
            • 1405
            Yes! It's only thin aluminium.
            Saturate it with "Gunk" engine cleaner and then hose it down with water from inside the engine comparment forcing the water forwards to push all the gunk out towards the front.
            You don't have to take the "funnel" off if you don't want to.
            John
            • urS6
              • Dec 2007
              • 35
              How 2 tips
              Thanks John
              1995 urS6(m) - sold
              Jozi, RSA
              • steve1234
                • Jan 2007
                • 205
                use a vacuum cleaner, you will find the oil cooler falls apart if there has been muck in there for a long time. all the best steve
                • jade
                  • Jan 2005
                  • 1811
                  Originally posted by urS6
                  Hi
                  Any tips apreciated
                  Thanks
                  If it needs more than petrol or another strong degreaser to clean it
                  It probably needs to be replaced
                  RS 2 580HP
                  • Avanter
                    • Nov 2008
                    • 35
                    • Country: Latvia
                    Try Brake cleaner
                    • AUDIS2avant
                      • Jan 2009
                      • 670
                      • Country: Denmark
                      Yep, brake cleaner and hot water after
