I am after some advice on building up my engine.
I have some Graphogen, a colloidal graphite paste that I understand you are supposed to use on all moving parts - becasue oil will drain away pretty quickly - and this will save wear on things during startup.
Is it safe to use this on the hydraulic tappets? I don't know if this is likely to block the oil feed to them? I was oging to put the head on the block before I fit the followers and cams/etc as I don't want any oil coming out the head to contaminate the headgasket - but if it is safe to use the graphogen grease I can build the head up ready for the block.
I have also heard it is not a good idea to use graphogen on the cylinder bores - any comments?
I am after any advice or tips for doing this properly.
Thanks
Thanks
Check them again once the engine has done a 100 miles or so. At this piont your bores will be bedding in and the figure should have improved. Once your happy that the bedding in is done, get a final figure to keep as a reference for future troubleshooting (hopefully wont be needed).
