ABY engine rebuild cost?
It depends what your goals are.
The original question included the term 'freshen up', and specified no rod upgrades. In most cases a re-hone and a new set of rings with the original block and pistons will do IMHO. Main and big end shells shouldn't have any significant wear, so no need to change them for the sake of it. Oil pump? Is that going to be knackered? Not IME.
So a bore hone, new rings, new valve guides and a full set of gaskets isn't going to cost much on top of the normal service items. Sure you can add a loads more jobs if you want, but are they needed?SSComment
