Tried beating mine... still didnt work.
Even shaved a couple of mm off the edge of the plastic throttle bit that rotates.
Had no choice but to either lower the engine or cut the metal... a few hours before setting off to the ring. The engine doesnt look like it will go any lower than it already is by adjusting the mounts though.
My cut-n-shut method is tried and testing, ring approved
Edit: While the bonnet way shut and the throttle may rotate all the way you need to bear in mind that when you go WOT the engine tilts upwards, which is what was causing mine to stick even with the plastic removed.
