Anybody got a spare crank sensor?
  • JamesHarrold
    • Feb 2008
    • 245
    STILL trying to sort out my problem.
    Has anybody got a spare crankshaft sensor knocking around that I could try...
    (for an ABY)
    Cheers guys
    James
  • JamesHarrold
    • Feb 2008
    • 245
    Or would this one be the right one.....? looks cheap
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=370186813622
    James
    • terrybullwon
      • Mar 2006
      • 8782
      i have 2 or 3 i think you can have one for a £10 posted
      Chef
      • JamesHarrold
        • Feb 2008
        • 245
        Thats great - Thanks!
        Will PM you
        James
          (for an ABY) Cheers guys James
          James: It might not be the crank sensor:
          Here is some crank sensor info (note crank sensor pin):
          http://forums.audiworld.com/showthread.php?p=18839940
          In reality, the pin is squarish (as shown at "8 o'clock" in this post):
          http://forums.audiworld.com/showthread.php?t=2746938
          The pin has been known to take early retirement and buy a cottage in Cornwall.
          If it has gone, it is possible to fab a new one from square stock and, if you or your mechanic are clever, weld it to the flywheel through the starter hole.
          • JamesHarrold
            • Feb 2008
            • 245
            Thanks for the links UrS4boy...
            Think I have a 2nd hand sensor to try....will let you know what happens
            James
              James,
              Don't know what it is, but have you double-checked all of the wiring, where you can?
              What I'm thinking of, as this problem is going on for you for a long time, is that maybe somewhere there is a frayed cut or damaged wire(s).
              Just a suggestion.
              I presume you've pressure tested all of the pipes, vacuum and boost including the intercooler ?
              If you ever find the problem before you burn it, please do post the cause of the heartache?
              Wishing you maximum luck with it.
              Get a drive / lift in someone elses, just to keep your faith in tact.
              Kind regards.
