Hi,
Just got home and next door neighbour was having something delivered hence blocking the drive so i parked up the road. 2 mins later the truck moved so I tried to start the car, turned the key.........and nothing The engine didnt make even the slightest attempt to turn over...just the dreaded click.
Any ideas, can was running fine up until then and hasn't exhibited any faults related to this to date.
I will go an try to restart it in about 5 minutes but all suggestions welcome
Thanks,
David
Thanks,
David
