Mechanical boost far too low
  • Dr H
    • 1175
    Originally posted by S2central.net
    Well fook me. My car runs at 1.4bar max with the WGFV connected, but only 0.4bar with it disconnected. Just tested it 2nite to be absolutely certain. I had previously read/heard that the stock WG and spring position (like mine) is good for 0.6 'mechanical boost' but its obviously not the case...
    Its actually a very good valet mode stunt with the WGFV disconnected. Looks like Leighs WG is ok from a sanity check against this.
    Well I don't know if that is good or bad news as it possibly rules out another potential for my problem
    • Mihnea
      • 1288
      0.4 Bar is the standard mechanical boost on all 20vt's mate, I had told ya before already
      No idea for Leigh's issue though...
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
        Very true on the valet mode, ive used that a few times
        • Dr H
          • 1175
          Did notice the needle on the boost guage fluttering a bit the other day. Someone has suggested that this and my other symptoms could point to a faulty WG. It gets up to pressure the WG opens to release some then doesn't close properly and lets too much out.
          If I let off the throttle and then boot it again it will get back up to pressure and then drop again etc. etc.
          Just out of interest how much is a WG diaphragm?
          • Markus
            • 184
            I'll second that.
            I had some overboosting problems today (which I need to solve before I install the homefry), so I disconnected the WGFV electrical connector and got max. 0,5 bar boost (perhaps a tad less) on my gauge.
            Totally transformed even a stock ABY to something much less fun...
            Markus
            '94 Kristallsilber-metallic S2 Avant.
              im in the same boat at the min, waiting for a new WGFV to arrive which will hopefully fix my problem. Mark H had a similar problem with his last year and it turned out to be just that.
              • audiman
                • 4827
                Can also produce boost spikes! I had boost rise to 2.3 bar before i noticed the gauge and backed off, hasnt done it since! (Went like hell)
                Tom C - www.rcmr.co.uk
                Audi UR Quattro
                Audi 100 C3 2.0 5 cyl 115ps
                Audi B5 RS4 645ps 911nm
