Hi again folks.
I thought i had a blown MAF yesterday so after S2Central asured me that i could use an AAN maf i tested it today, but still the car is running like crap.
It started out a few weeks ago, sometimes when starting in 1.gear the car hesitated for a second or 2 before it came like a rocket, then the same did happened a few times in 2.gear, otherwise running strong and great.
The other day it really started to misbehave so i thought i was almost out of gas (gauge was very low and i was on the way to the gas station anyway) filled up the tank and still the car wasn't acting right, it got worse and worse on the way home, actually so bad i had to do 35mph on the highway just to get the car home.
Symptoms:
Idles great when cold, but idle is a bit unstable when worm.
As soon as trying to build boost it just coughs,misfires, refuses to build boost over 0.3-0.4 and acts all strange
No fault codes from Vag-Com
So i'm thinking boost leakage, (but shouldn't vag-com then show the "Maximum Boost Preasure exceed" ?
Low fuelpreasure?
Would a stuck Bypassvalve lead to any of these symptoms?
Coils,sparkplugs and all that is almost new.
Thanks in advance for any opinion.
Jan
Symptoms:
Low fuelpreasure?
Jan
I Hate myself
So gotta continue that search today
