i am trying to fit a afr gauge ,does anyone know which is the signal wire to the ecu ,as this is the one i need to conect into..any help appreciated as i cannot read wiring diagrams.
on the lambda sensor there are 3 wires,2 white and 1 black on its own with a spade connector ,thanks martyn
Be interested to see how accurate that is - WBo2 guages are much more reactive, and expensive... but a cheap and cheerful one might be a nice way to keep an eye on mixture without costing the earth and bringing lots of baggage.
its only a cheap one for now,prosport,i just wanted to keep on eye on things whilst running in,i bought it together with egt gauge..will be replacing them for better itemswhen funds allow,i have spent sooo much on this project
