Did some new power and torque measurements with the MR Dyno. For the first time, I also included a 4th gear pull, but limited it to 5300rpm because that was approaching twice the speed limit. Still, that pull produced the highest whp number, even though 5300rpm is well below the rpm of peak power.
Slightly above 2bar peak boost on Turbonetics E50 turbo with E85 fuel in the tank:
Numbers uncorrected for 12 deg C ambient:
408ps og 562nm at the wheels in 4th gear (limited to 5300rpm)
406ps og 530nm in 3rd
401ps og 510nm in 2nd
The graphs show that 3rd and 4th gear pulls will produce pretty similar results, even though 4th gear numbers are still higher. I guess 4th gear would have produced approx 415-420hp at the wheels if the run had been taken to redline.
In 2nd gear the torque curve suffers greatly, because the turbo spools approx 1000rpm later.
A new Porsche Cayman S that wanted to strut its stuff got beaten. With a sound margin.. nice engine tone in that Porsche, though.
Interestingly, peak G-force in 4th gear was 0.45G. That is 10% more G-Force than I recorded peak in 2nd gear on a 350hp 4.2L S6+, just in case someone had forgotten why we like turbos
Graph 1 shows torque at the wheels in 2nd vs 3rd vs 4th gear
Graph 2 shows power at the wheels in 2nd vs 3rd vs 4th gear
