cam shaft
  • kaaperdaja
    • Sep 2003
    • 143
    cam shaft
    Does anyone know what other crank shaft can I use to replace the 3B one if there is any other that fits? I might need a new crank shaft but don't know for sure yet.
  • timucin
    • Nov 2003
    • 869
    • Country: Turkey
    crank or cam?
    Quattro
    • kaaperdaja
      • Sep 2003
      • 143
      I think it's english word is crank. (Not the one that you can replace with 7A one for better performance).
      • Stick Insect
        • Dec 2003
        • 2338
        Kaaperdaja, The crankshaft is the one which has the conrods and pistons and is at the bottom of the engine.
        I assume that is the one which has failed.
        David
        • kaaperdaja
          • Sep 2003
          • 143
          Yes, I don't know yet if I can use the old one or not. Just want to know what options do I have if I can't use the old one. I even don't want to know how much new costs...
          • kaaperdaja
            • Sep 2003
            • 143
            Ok, now I'm in a need of new crank shaft because the old one is ruined. Does anyone have information if 7A crank shaft goes to 3B engine too or not?
            • urquattrob81
              • 259
              7A and 3B are the same so, you can use it
              • timucin
                • Nov 2003
                • 869
                • Country: Turkey
                are they higher on lift?
                or more degrees?
                Quattro
