7A Diagnostic Code Reader that Works!
  • cexley
    • Dec 2007
    • 20
    After zero success with VAG-COM and months of research, I have finally found diag code reader that works with the dreaded Hitachi ECU. Product is the QUICKLYNKS T45E Hand Held Scanner. Costs £34.99 off eBay. You'll need a 2x2 conversion cable (I used my VAG-COM 2x2) or order one with it. Works a treat. Give the car a good run, rev it to over 3k in third gear. Park up leave engine running (Do NOT turn it off). Plug in the QuickLynks and watch the ECU finally confess all its problems. Brill - no more grovelling around with Led's and working out blink codes etc.
    85' 80 Sport, 90' Coupe 2.3E, 90' 2.3 20V Coupe Quattro, 93' 80 Avant 2.6 SE, 95' A6 Avant 2.5 TDi Se, 98' A6 1.9 TDi SE, 95 S2 Avant
  • mcandmar
    • Apr 2004
    • 5118
    Vagcom works fine with the 7A, well the genuine ross-tech version does anyway. That does sound a better option as vagcom is a little overkill for the 7A being limited by low connection speed and a single measuring block. Thats also a lot cheaper.....
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • Flat on my back
      • Jan 2007
      • 2449
      I can't find them on ebay...
      Need a linky for the thickies...
      Carlos.
      • haaran
        • Apr 2009
        • 236
        Do you know if this new thing works on S2's?
        Audi S2 Avant, 1995, ...and it begins with a Homefry
        Audi 80 Sport, 1986, ...my first car...wish I still had it
        • haaran
          • Apr 2009
          • 236
          http://cgi.ebay.co.uk/CAR-CODE-READE...3%3A1|294%3A50
          here we go...and I can answer my own question too...apparently works on the S2 aswell.
            Can't use VAGcom on the early 7As
            Never found the blink codes a problem to be honest, I've set mine up with an LED in the blank slot in the instrument housing for the Air Bag, then with a push switch under the drivers glove tray to bridge the connectors so I can read the codes without needing to mess about under the dash
              Y'all know about the fuse trick in the relay on a 7A don't ya ?
                errr... don't think so
                can you elaborate?
                • mcandmar
                  • Apr 2004
                  • 5118
                  Not sure, only ever used it for the idle speed adjustment, or does it do something else?
                    what is the fuse trick you speak of?
                    • mcandmar
                      • Apr 2004
                      • 5118
                      It puts the ECU into a default mode with pre-defined settings, disables O2 sensor control, sets static ignition timing and does a few other things for the purpose of setting up the base idle speed etc. I get the impression Paul knows something we dont in relation to the fault codes diag circuit
                        Never heard of this - is it on 20v.org?
                        How do you do it / useful purposes?
                          Let me dig it out later... Its an oddball I found for these MPI systems - 7A, NM and AAH (V6) - think it was year specific too.
                          • Flat on my back
                            • Jan 2007
                            • 2449
                            Well...
                            We're waiting...
                            Carlos.
                              This reminds me, i was going to send you my ECU to look at wasn't I Paul
                              I'll try and remember while my cars in bits
