evening chaps, been having a bit of an issue with poor idle when the car is cold for a few mins then its fine after that. The revs tend to drop and it hunts a little, then when on part throttle it feels like it holds back for a second then is ok again. After about 5 mins warming up the issue disappears completely.
Any Ideas? I have cleaned the ISV already but that hasnt solved it.
Also I pulled the codes this evening.
The codes stored were:
00537 - Lambda sensor control
- Maximum control limit exceeded
- Minimum control limit exceeded
00525 - Lambda Sensor, G39
- Signal to B+
- Signal to ground
- No change in signal
65535 - Engine Control Module Malfunctioning
I then cleared the codes and re checked them and the 65535 code remained but the others cleared.
Now there seems to be a common theme on the descriptions for the fault codes on S2central:
• Check J220 wiring, B+ and ground connections
• Ground wire between pin 10 on J220 and engine block open circuit
• Open circuit to J220
Now my questions is what is J220 and pin 10 since it looks that it could likely be an earthing problem that needs to be sorted out to solve these issues.
- Signal to B+
- Signal to ground
