10v camshafts
  • goodall
    • Jul 2008
    • 810
    10v camshafts
    which 10v camshaft is the best stock with out having to buy a new shaft
    would be any advantage to using a a diesel cam cut down and with a gear for the dizzy, this is a for a n/a application aswel
  • slow2
    • Apr 2004
    • 238
    Rolf harris tip, "Tie me Cam Guru down boy" :mischeif:
    Dez
    Never did overtime until i purchased........s2
    • Rusty
      • 18953
      Get an aftermarket cam for £200-£250, should give it a lot better breathing higher up the revs. NA 270 cams are quite nice or the 285 if you're feeling mad.
