still got afterrun sequence probs
  • s2martyn
    Banned
    • Apr 2008
    • 408
    when i join the 2 wires to the afterrun pump sensor,the pump works as normal BUT the radiator fan does not operate at the same time...the fan works as it should in traffic and i have also checked the 2 speeds of the fan by bridging the thermo switch connections..i have also replaced the relay for afterrun(no 14) and also relay no3 fan delay..i am asuming the no.14 relay is not sending a signal to the no.3 relay???any help appreciated as i dont want anything to **** up.thanks martyn
