S2 wheres all the acceleration gone!!??
  • S2-5speed
    • May 2009
    • 22
    Hi
    Im new to the forum and new to my S2,Had a couple of audis in the past A4s and a 225 TT.Always wanted a S2, and wife allowing finaly got one!!
    My S2 has 175k full maindealer history with all receipts and had lots of money spent on her.
    The S2 seems very under powered, this has got to a problem as the acceleration is very poor (as fast as my 1.7 diesel Astravan), pinking when throttle down and at 3000rpm long flat spot until eventualy gets to 4500rpm 60mph up all seems ok,
    It has just had a new throttle body, I Replaced Ignition leads and rocker gasket as oil was leaking in to sparkplug locations and into distributor cap I was hoping that was the problem,but its still there.
    OBD2 shows no faults..
    I would appreciate any help and advice you guy have,as pulling my hair out(and theres not a lot there to start with)
  • terrybullwon
    • Mar 2006
    • 8782
    Sounds like it could be simple as a boost leak. These cars are getting older now and the hoses are not to smart, rose motor sport do a set or some one else...
    Chef
    • dest
      • 4287
      Welcome
      I would say its definitly a boost leak, search the forum and you will find tons of info about them. Have a search for the "Mark H nod" too, which replaces the o ring real between the cross member pipe and intercooler, which is a common place for them to leak
        As above, uaually is one of these, I had one 2 weeks ago after refitting a pipe and leaving the connector a tad loose, blew the hose off the intercooler
        It can take a while to go over the car and get it all sorted for boost leaks etc. but when you get it all sorted it'll fly
        Other thing is to check it's got the correct F5DPOR plugs too, standard plugs won't cut it.
        Pinking is a strange symptom... boost leak would lead to rich running so unlikely to det. Could be timing, not sure how it's controlled on a 3B tho (5 speed).
        • S2-5speed
          • May 2009
          • 22
          Excellent
          Thanks for the replies. A hour or so under the bonnet and shold be sorted hopfully.
          thanks again..
          • dest
            • 4287
            I bet its the same as my blue one was, the pinking feels like a misfire or if its alternating between on and off boost really quickly
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              1. Beg, borrow or steal a boost gauge as the comments above are certain to be the answer and the boost gauge will confirm it
              2. Beg, borrow or buy from AndyP a pressure test kit
              3. Fit new hoses/clips as required
              4. upgrade to Porsche brakes
              5. Konis and Upgraded ARB's and suspension bushes
              6. HOMEFRIES!!!!!
              7. Confuse the hell out of everything on the road as a 15 year old Audi 80 Spanks them
              Cheers n
              Si
              Subtle mods here and there
              2011 A5 3.0 TDi - Lava Grey
              • terrybullwon
                • Mar 2006
                • 8782
                6. HOMEFRIES!!!!!
                Cheers n
                Si
                I have a presure testing kit i can sell
                Chef
                • S2-5speed
                  • May 2009
                  • 22
                  You guys were right.. just stripped it down the lower bellows pipe has worn through together with thin braided pipe that runs along it any ideas cost?? the thin pipe I guess can be spliced a hollow pipe inserted and jubilee clamped the bellows pipe will need replacing..
                    Best to replace with Silicon items IMO.
                    Get that test kit too
                    Boost gauge can e sourced for <£30 and are simple enough to plumb in.
