Hi guys.
Am having a slight misfire problem atm( same symptoms as when spark is not powerfull enough ) , it´s only on 80% throttle and up to wot, otherwise nothing, BUT car also feels like it´s much faster on half throttle then on full throttle?
Car also feels a LOT stronger in the rain and when engine is in warm up.
Is this something simple?
Could this be caused by a defekt inlet temp sensor?
Maybe MFTS even as this is new? (i think it reads a little high on the meter in the dash)
Could it be caused by an bad fuel filter as i think this has never been changed?
Could it be caused by an 3b WGFV as my engine is an aby?
Any ideas?
Btw, have checked for boost leaks
Any ideas?
