kkk 26 turbo ????
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    kkk 26 turbo ????
    can somebody thell me what's is this for a turbo???
    number: kkk 26 14-70
    cold side 3526-101-5160
    hot side 5328-101-8362 G
    I find out it is biger than k24 ,cold side is like rs2 turbo,but hot side is not the same...
    now i want to find out,hou mutch HP or boost can deliver this turbo?
    please can somebody help me....
    thanks...
  • Ian Simmonds
    • Jun 2005
    • 2858
    Now don't go quoting me on this... (Because I can't confirm part numbers quoted)...
    But the KKK26K was the turbo for a WR Ur quattro, so if its missing water cooling, it's an early 80's WR turbo....
    93 MTMS2 Avant
    • rs200
      • May 2009
      • 1398
      • Home: Croatia
      no it's not from urquattro.
      they have u water cooling and it is from 1995. year.
      the turbo was taken from s2 mtm ,aby engine.
      • rs200
        • May 2009
        • 1398
        • Home: Croatia
        here is a pitcure of this kkk 26 and kkk 24
        • rs200
          • May 2009
          • 1398
          • Home: Croatia
          [IMG][/IMG]
          • kwlw
            • Sep 2004
            • 1025
            • Country: Lithuania
            Is there number 953279051 on the blue plate? If it is, I remember something, that it is some kind of identical to RS2 turbo (replacement unit?). However hot side number confuses me. Not typical for mass production units I have seen.
            If turbine outlet is same size as RS2 turbo, then compressor delivered air will be roughly the same (same rpm, same back pressure).
            Sau
            • europeanme
              • Oct 2005
              • 3817
              could it be a hybrid/special??...
              • rs200
                • May 2009
                • 1398
                • Home: Croatia
                Sau
                20 471 90 50 this is a number on a blue plate.
                you mean this turbo will be enaugh for 340-350 hp?
                • rs200
                  • May 2009
                  • 1398
                  • Home: Croatia
                  now i find what my turbo is....
                  here is the link:
                  thanks...
