DumpValve install??
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    DumpValve install??
    How have you guys installed yours?
    Boost in the side, and vent out the bottom?
    or viceversa?
    Have just installed mine according to the instructions, but i think it´s acting strange
    The correct orientation is the control port pointed towards the chassis leg...
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      found out paul, and it was acting strange cause the ecu had to adapt, working perfect now
      • driftin jo
        • Sep 2007
        • 2222
        I don't understand ?! what has the ecu got to adapt to ?
        • AUDIS2avant
          • Jan 2009
          • 670
          • Country: Denmark
          The old DV was leaking A LOT, so it gets quicker boost, more boost in some rpm(between 3k-5k rpm) and it holds the boost as it should, not fluctuate all over the place.
          It had to "learn" the new boost curve (i think at least)
          After 5-6 full throttle 2-3-4gear acc it was spot on
          • driftin jo
            • Sep 2007
            • 2222
            I see, that seems to make sence.
