Fault code 65535 / blink 1111
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    Can anyone one please give me a bit more info on this code
    Faulty control unit j220 would that be the ECU ?
    -Earth connection to J220 contacts 10,14,19,24 that would be the 55 pin connector
    ECU has a earth strap with a good connection
    Thanks Wayne
    RS 2 580HP
    Check earths on the inlet manifold are clean and tight.
    • jade
      • Jan 2005
      • 1811
      Help with fault codes
      I will do, but i did pay attention to these when connected wiring
      Also showing 00519 2222
      And 00514 2212 g69 tried the tests on it looks ok the zt-2 show voltage going up & down.
      The zt-2 read,s 100% closed & 5% fully open is that right thought it would be the other way round
      RS 2 580HP
      • jade
        • Jan 2005
        • 1811
        Checked earth's all good, checked pins 10 14 19 24 on the 55 pin connector they all earth to the body so they look ok
        Any advise on the other faults codes I have would be appreciated
        2212 / 00518
        2222 / 00519
        RS 2 580HP
        • A80Avant
          • 10873
          • Country: Greece
          00519 is : internal ECU pressure sensor fault
          00519 - VAG1551/2 Fault Code Number
          ECU Internal Pressure sensor (G71)
          Pressure sensor defective,
          Repair or replace ECU or replace internal pressure sensor
          00519 Manifold Absolute Pressure Sensor
          - Signal too low
          - Signal too high
          - Control difference
          00518 has to do with TPS. is that wired properly?
          • jade
            • Jan 2005
            • 1811
            - Signal too low
            - Signal too high
            g71 would be the map sensor strange it worked fine before i will double check all vac lines
            I have 5v at the TPS resistant looks ok
            But i did just measure 3.8 with throttle fully open on pins 2 & 3 that could be the problem there i will double check this.
            Thanks for your input
            RS 2 580HP
            • jade
              • Jan 2005
              • 1811
              Ok TPS have 5v on 1&2 2&3 have 3.6 going out' So this hopefully is the problem change switch
              RS 2 580HP
              • s2_bo
                • Oct 2005
                • 6067
                What voltage should they have when its at WOT?
                91 S2 coupé - RIP
                98 S8 - Luxury barge
                • jade
                  • Jan 2005
                  • 1811
                  PIN 2 - 3 + 4.6v full throttle
                  RS 2 580HP
                  • jade
                    • Jan 2005
                    • 1811
                    I Have finlly got rid of most of my fault codes
                    Today when i pulled the codes I got 65535 / 1111 & 4444 which is no faults to show that was first then followed by 1111
                    I have tested the pins on ecu 10 14 19 24 seems to earth well, because of my Furans i had to change the location of earths one is on the cam cover & the other is on the last inlet manifold bolt firmly done up.
                    Any ideas please on this, because i am keen to remap but need to get to the bottom of these fault codes first.
                    Thanks Wayne
                    RS 2 580HP
                      Has the ECU been remapped already ?
                      If so - there is a good chance that a bad checksum is throwing up this fault code...
                      • jade
                        • Jan 2005
                        • 1811
                        No car has not been mapped yet, Hoping to do that soon
                        Regards Wayne
                        RS 2 580HP
                          Mmmm - thats normally the cause of 65535 - that or certain MAP failures inside...
                          • jade
                            • Jan 2005
                            • 1811
                            Map was fine before strange if it's just given up now
                            I am presently running on a comp ct 458 with the old chips, would this do it ???
                            RS 2 580HP
                              Nope - that doesn't have anything related...
