I have a problem with my S2 ABY '94. When i put off my car after driving, the water begins to boil in the hose coming from the watermanifold to the big radiator. When i'm driving, the water stays 90°C and the water won't boil. When the car is idling there is still no problem, car gets to 92°C then the fan will kick in, water still not boilling. It begins to boil as soon as i put the motor off, when their is no watercirculation. It only boils in the watermanifoldhose. Weird is that the afterrunpump won't work cause the sensor of the pump is in the manifold where the water seems to boil. The temperature stays normal on the dashgauge. I' have no waterleaks.
So i tought it was my afterrunpump, i've changed it together with 2 sensors in watermanifold + sensor in the big radiator(also new). I've also tested the pump by connecting the 2 wires from the afterrunpump sensor, it works.
After changing all this still had the problem, so i've brought my S2 to the audigarage. First they tought it was cylinderheadgasketleak, but it wasn't. They searched for two weeks, today they called me to say the car was OK. So i drove it home, when i got home and putted the motor off, it was still boiling. Called the garage, they say that they can't do nothing anymore, that everything was checked correct and that it is normal that it boils a "littlebit". Now, I think this is not normal.
Does anyone here on the forum has had a similar problem? don't know what to do.
grtz
grtz
