Garrett Turbos
    Garrett Turbos
    Yep - a closer look at the Garret GT30R and GT35 confirms they are both viable for high boost applications on the S2/RS2 engines.
    Based on my calcs (from Corky Bell and other sources) I get a corrected airflow rate of ~48lbs/min at 7000rpm with VE=85% and Boost=1.8bar. That would need an uprated bottom end but the GT30R will *just* be happy with PR=3 without running into choke.
    The GT35R has additional headroom and could sustain PR=3.2 at this engine speed.
    Looking at the surge lines, assuming PR=3 from 4000rpm then the GT30R would be just OK - within surge limits, but the GT35R would definitely be unhappy with this condition - it is optimised for generating high PR values at high engine speeds only.
    So my gut feel appears to be about right with the GT30R being a much better choice for road use. It would sustain PR=3.2 between 4500 and 6000rpm.
    I'll write this analysis up properly sometime, but I'd like feedback from Marco, Mihnea and others on my brief summary here.
    For reference I am assuming Delta P across a good intercooler of 2psi and Delta P across the air filter of 0.5psi as per Garretts guidelines for calculating PR.
    I'd need a little more time on the spreadsheet to calculate a suitable boost profile on the GT30R so that it doesn't have surge problems at lower RPM.
    Paul
    PS - I'm lookng at the GT30R map for 700382-12 with the 56 Trim compressor wheel... I haven't got my head round the turbine wheel choices yet with regards A/R, but the 0.82 choice would appear to have less lag, so thats what I'd go for on a road car.
    Oh and the GT35R would appear to be better in a 2.5L application at first sniff. Evidence to follow sometime next week when I get plotting some graphs
  • diesel des
    • 3896
    Paul
    Paul thats pritty much what i had worked out. Peak boost and torque from about 4k. And happy at 2 bar of boost at 7+K rpm at the top end. I went for the same trim of comp you are talking about eg 56 with a Ar 0f 0.6 on the 77mm wheel compressor and the 0.82 ar turbine. I plan on useing it on a stock bottom end, and hope that with some cleaver Mihnea mapping it will stick together at 1.8bar boost at 7Krpm giving near 400BHP at the wheels or what ever Mihnea reckons is safe. Apparently its the low and mid range big boost and torque that bend the rods so with that limited the engine should just hold up.
    Obviously i will use a BIG intercooler and have 7a cams, tube manifold etc, etc. Ohh, its going in a URQ. thanks,des.
    • salmon
      • May 2004
      • 134
      Out of interest what is the standard turbo fitted to an S2.
      Been under mine today to fix the starter (which required a slight knock) and the only markings I can see are KKK?
        I believe it is a K24
        • Beetie
          • Oct 2003
          • 1517
          Correct mate!
          Was a '93 3B, Dont ask now tho......
            Good luck with that on the stock bottom end. I'd fear for the integrity of conrods at 1.8bar at 7000rpm myself. Have you done the fuel calcs yet ?
            Dunno for sure if green injectors are up to that spec with the S2 or RS2 fuel system - you might need a Bosch mosport pump and 5bar FPR. Failing that Mihnea can source some HUGE sized injectors for you if needed...
            Let us know how you get on with the GT30R !
            What EM are you planning on using - the 'S1' from MTM or something custom ?
            Paul
            • Mihnea
              • 1288
              Des, Paul:
              On a stock bottom end, I won't ever exceed 1.7 Bar peak and 1.3 at 7000 RPM with such a compressor, never ever!!! Even though it might not make a peep hole in the block in the first 10k miles, it's not safe and will wear your engine out very quickly.
              If you really want to use the potential of that turbo, get a good set of rods, all new bearings and check all clearances, drop the CR a bit (I'd say around 8:1 is ideal), Bosch motorsport fuel pump, 4 Bar FPR, big injectors (I have 440cc@3Bar available, at 4 Bar rail pressure they do supply 510cc/min) and then we have a shot for a monster engine that will remain pretty reliable...
              But on the stock bottom end and compression ratio, I'm sure we'll have to drop boost in order for the engine not to ping like a church bell before anything else...
              Cheers,
              Mihnea
              www.MRCTuning.com
              info@MRCTuning.com
              Workshop Directions
              • Pisobiker
                • 1175
                .....I'll write this analysis up properly sometime, but I'd like feedback from Marco, Mihnea and others on my brief summary here.
                Looks correct to me.
                Marco
                  Cool Marco - whats your thoughts on a VE assumption of 85% for the stock engine across the rev range ?
                  WOuld a sweetly polished head like MarkH's take the VE to 90% or better - whats your gut feel ?
                  Paul
                  • diesel des
                    • 3896
                    Originally posted by Mihnea
                    Des, Paul:
                    Cheers,
                    Mihnea
                    Mihnea , you are the man i hope to map my URQ with this combo when finished. Dont worry, it will be a while yet. It takes a Looooong time to save up the cash . I plan on using those big injectors you talk about etc. But i had read from some of your posts that with all the right bits added to say a RS2, eg, turbo, tube manifold, injectors, cams, intercooler, exhaust etc, BUT a sotck bottom end you could chip to 400BHP easy. Is this wrong? I will be running a Gt 30R, Rs tuning manifold, 7a cams, big intercooler, big exhaust, your injectors all in a aby in a URQ. I will run the car for fast road use and track days, not every day, but i will super unleaded 97 ron at least. It must last some time, not just a day, but not 100K miles though. What do you reckon is safe boost wise, torque and Bhp? Whats that bhp at the wheels on a 016 box? I could add a shim to the head to lower the Compression ratio, but am worried about stuffing up the squish and getting more ping. What do you think? This month i am geting the manifold, next moth some parts from you i hope. One part at a time. Thanks, des.
                    • Pisobiker
                      • 1175
                      Paul
                      Paul, I think you might have been a little pessimistic regarding VE. Actually our 4 valves heads look quite good to me, but, of course, not having flow charts of any kind it's not possible to tell.
                      I think, anyway, on OEM or RS2 camshafs, VE might go up to 90% in the midrange, while at top rpm it might actually drop a bit.
                      Let me say that the lower the OEM VE the better it is.....
                      Yeah, thas right, I'm not crazy (.... err..... maybe slightly... ):
                      the lower the OEM VE the highest the gains obtainable with porting and polishing + optimizing intake and exhaust layouts. If our heads already produced lets say 98% VE, than any effort on raising it, no matter how much money and how many ours on the flowbanch, would only produce very small gains.
                      If some of the "high performance" guys here would like, there is a pretty easy test I can think of to check VE differences while upgrading bits:
                      1) Disconnect WGFV plug so that boost will be fixed at the 0.6-0.7 bar "safety mode", without the ECU being allowed to mess up the outputs while trying to eventually compensate flow increases with boost changes... ;
                      2) Dyno test your car with the original setup;
                      3) Install new head;
                      4) Dyno test your car again (always with WGFV unplugged).
                      All other parameters must stay the same (same dyno banch, ext temp, barometric pressure.... etc.) so that % hp gained approximatly shows effective % increase in VE.
                      Do the same test with any other intake/exhaust mod.
                      Increasing VE and flowing efficiency of IC and inlet ducts is of course very effective in any high boost application (in my opinion anything above 1.5 bar boost is the case).
                      As a matter of fact compressor is probably working in a "mid-to-low" efficiency area, therefore transferring a lot of heat to the charge. Any imporvement in the inlet to compressor (air filter, MAF, MAF to compressor duct) which will affect P1, and any improvement in the IC + ducting + IM + head flow, will allow at same IM boost to run lower compressor P2/P1 ratios, therefore having denser charge (more power) and cooler charge which allowes more aggressive ignition timing (more power again).
                      Marco
                        Paul, did you ever investigate the GT28R suitability to the S2?, i ask because this seems to be very popular with the Fiat Coupe's 20V turbo's
                          Funny enough - I recommended EXACTLY that turbo to someone I met recently who owns such a car - I checked out the compressor map against that application and it looks good.
                          As for suitability to the S2 - I'd say no 'cos that Garrett turbo has an integral wastegate - as opposed to the superior external WG that we all have.
                          Paul
                          • audiman
                            • 4827
                            Des, sounds like you combo will be putting out somewhere in the region of 370bhp @flywheel. With the bottom end stock it wont take it. Boost will be limited to 1.7-1.8 and will have to tail off to about 1.2 at redline. Shimming the head is one way, but that wont last. Either skim pistons or buy custom ones. and replace the rods. Its the only way. I have bent a rod at 1.8bar. And thats with boost low at top end!
                            Tom C - www.rcmr.co.uk
                            Audi UR Quattro
                            Audi 100 C3 2.0 5 cyl 115ps
                            Audi B5 RS4 645ps 911nm
                            • sal_s2
                              • 1287
                              So is the gt35r out of the question?
                              If I used one of these, what would the characterisics of the engine be?
