Hi all!
I finished my ABY to ADU upgrade, and I fit a RS2 ECU.
From 0 to 0'4-0'5 bar all is OK, but when I go more than 0'5 bar, the engine fails and don't run OK.
I tried the engine with vag-com, and all is OK.
I suspect than the problem is the ECU, because if I don't go more than 0'4bar the engine runs very very good!
How can I check if the ECU is bad?
Cheers!
Cheers!
