Sounds a bit strange, sure it's not just that it gets to the end of 4th so quickly? Suggest that you check for a boost leak, just a little one can lose you quite a few bhp, I gained nearly 25 after fixing a little leak
A stock S2 does slow down above about 130 but it's still not 'slow'. The extra oomph of the RS2 turbo should see it pulling harder up top tho.
Do some performance testing (0-100 for example) and that'll tell you if it's working right, my Homefries S2 is between 12.5 and 13s 0-100.
