Help - rough / hesitant when warm!
This sounds a bit like the problem I've had in the past. How does it idle when the engine is hot? Does it hunt up and down? In any case, this sounds to me like the O2 (Lambda) sensor is fading out. When was it last replaced? -
I've started using my S2 Avant as my daily drive for the last couple of weeks now and it's been driving fine, although not as punchy as a month or so back (i'm thinking/hoping the weather may have something to do with that!).
Anyway, a couple of miles into my commute this morning, I could feel myself shaking in the drivers seat whilst standstill in traffic (belly was wobbling all over the place). The engine was sounding a little rough too. On moving, the car was very rough and noisy at low revs, and was hesitant like when you're jump starting an old battery or trying to start the car when it's ran out of fuel. Once it picked up some revs, it would get going, however, there was very little power there and i'd have to drop gears even for the slightest inclines. I could also smell burning rubber and occasionally fuel. It's doesn't cough/splutter excessively but definitely isn't sounding right when warm.
Had a look under the hood when I got to work but couldn't notice anything obvious apart from the engine shaking a lot more than usual.
After work, I started the car and all seemed 'normal' again, for the first couple of miles that is, and then it happened again.
What can it be?
CheersTags: None
