Hi,
i have a problem in my Rs2 and cylinder 3 is not working. I have spark and i see that the lambda value changes when i connect or disconnect the injector plug.
What could it be? Clogged up injectors (they are ca. 20000km on the car)
Are there any fuses or relais for the injectors on the car that i should check?
What else could it be?
thanks in advance
thanks in advance
