Pulled the following codes:
00516 - Throttle position sensor - closed switch F60
00561 - Mixture adjustment control
00553 - Mass Air flow sensor G70
00513 - Engine speed sensor
What problem do all these indicate to? Are they related to my current problem (link for thread below)? (I did disconnect the lambda sensor and air mass meter yesterday to see the effect on my current problem).
