Mihnea can do you a customised setup - optimised for the knock limits, MAF behaviour and fuel pressure on your car. I can do you a generic S2 upgrade that delivers 430Nm of peak torque and 280bhp at the top end.
AMD chips are indeed encrypted. WHat is very curious about an AMD installation I saw last year was that they only tweak the turbo chip and leave fuel and timing totally standard - ridiculous in my opinion.
Your car may just be low on fuel pressure or have lower knock tolerance than the chips would like.
With Mihnea's help I have made my chips even more generic than before to ensure there is more tolerance for different cars behaviours. A few tweaks on various compensation maps were needed to improve running on different fuel and at higher air temps.
Dunno if you'll make it to Mihnea' scottish tuning session. Obviously the car needs to be certified healthy (no air leaks etc) beforehand. I can send you my spare tweaked ECU if you'd like to test that against the AMD one. It will be late next week however.
Paul
Paul
