There's a whole episode in http://S2central.net about the radiator fan and how to test the after-run system - its pretty straightforward.
The after-run relay is in the auxiliary relay panel.
Testing the functionality is easy with a large bladed screwdriver to short the after-run temp switch. It will only run when the engine is off. The after-run relay has a 15min timer to shut off the pump should the switch fail closed. Actually this little trick is how MarkH gets his car to ALWAYS trigger after-run pump when he shuts his engine off. Neato...
You can also hear the pump be briefly tested when the turn the ignition on.
Welcome by the way !
Paul
Paul
(damn these boost problems).
