3B tuneability?
  • audinut
    • Jul 2009
    • 2195
    3B tuneability?
    im trying to find a previous thread which tells of the tuning possibilitys of the 3b without changing the internals ?
    can anyone lead me in some sort of direction as im struggling to decide wat s car to buy/look for
    many thanks
    NOT a car dealer! just an S2/RS2 enthusiast
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    many thanks
    300hp will can possible in a 3b with stock internals and externals and with bigger software/money you will can won all like you want
    • audinut
      • Jul 2009
      • 2195
      wat can the stock internals take on a 3b ? 300hp max? anyone got one that use daily? can the aby aan be more relaibly tuned?
      • s2driveruk
        • 12696
        Plenty running pretty close to that number (myself included) reliably and have been for several years. Obviously fairly easy to go much further than 300bhp but for that the serious money needs to be paid
        David
        1992 3b S2 Coupe
        • audinut
          • Jul 2009
          • 2195
          so its not really a question of 3b or aby /aan then? - id like to achieve 300hp and a max of 350hp i have no interest of going any further
          Its kind of difficult deciding where to spend the cash - whatever i get it will be stripped for a major overhaul anyway -
          although i have seen urs4 and urs6's for sale too so at the mo i kinda dont know what to do - my old s2 i enjoyed no end it really was the best car ive ever had so i just want that back really - but some tosspot nicked it !
          • s2_bo
            • Oct 2005
            • 6067
            Sorry to hear about someone nicking your car.
            280hp is easy with just a generic remap.
            If you want to spend a bit more you can achieve 300 buy adding an exhaust, rs2 airbox etc.
            for 350hp you need to start spending a fair amount as you will need a new turbo etc but internals should be fine as long as its properly mapped.
            imo, get a s2, then get a generic set of chips from someone like MRC for £250. and when you get board of that think again..
            91 S2 coupé - RIP
            98 S8 - Luxury barge
              On the 3B you need to change the head gasket from paper to metal also you'd need the ABY / RS2 hardened bearing.
              Headgasket being critical, Audiman tried it and blew it within days
              • s2_bo
                • Oct 2005
                • 6067
                Thats debatable imo.
                HG is only essential is your going for more then generic chips. I ran my 3b with 1.5bar boost for a couple of years and it was fine..
                91 S2 coupé - RIP
                • audinut
                  • Jul 2009
                  • 2195
                  il be removing the head any way so i will happily fit an uprated gasket , what is the bearing you talk of ?
                  • Rusty
                    • 18953
                    Basically stock internals are fine with a stock turbo, the RS2 turbo can be used with care, as can a small hybrid (Nothele or MTM style).
                    The bearings are either the main crank or big end bearings off an ADU (RS2).
                    • audinut
                      • Jul 2009
                      • 2195
                      well may as well do them too then as the block will be out too! lol
                      • s2driveruk
                        • 12696
                        some 3b's left the factory with a metal gasket
                        1992 3b S2 Coupe
                          1.5 is K24 boost as soon as you change the turbo to RS2 or larger it's required.
                            Yep notably the 93 models
                            For Bo, the words of MRC and Audiman posts 2 & 3 notice the gasket failed on 1.5 bar boost
                            • s2driveruk
                              • 12696
                              Aug 92 seems to have them too...at least mine would appear to have.
                              1992 3b S2 Coupe
