noise on start up
  • rocketdog
    • Feb 2009
    • 58
    noise on start up
    when i start my s2 on a morning there is a strange clicking/whining noise, its sounds like its coming from the front of the engine but it goes away after about 60 seconds, can anyone help?
  • Knight Rider S4
    • 3541
    Both posts you have put up my be the same thing ...How is the power steering?
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • irishs2
      • Apr 2009
      • 2455
      I'd say its related/connected to your other problem noise could be coming from power steering pump , a little bit of play being taken up when your bomb has built up enough pressure.
      Eric
      95 S2 Avant under rebuild.
      • rocketdog
        • Feb 2009
        • 58
        steering is fine apart from small knock near full lock but i think that is strut top bearings which will be repalced tomorrow. will disconnecting the switch on the pas fluid tank make any difference?
