Changed some parts and guess what !
  • DAVIDP20V
    • Dec 2003
    • 165
    still have the same fooking problem !
    today i changed the d/valve and wgfv and checked all pipes round the inlet area ! !
    just to remind you car drives fine, put my foot down it boost's right round to over 20 psi with a lot of stuttering/misfire then resorts to 5 psi of boost. like a safe mode ?!? help me
    leave it a bit put my foot down again and guess what ..........gives full boost
    until the 5 psi bit rears its head.
    also after a test run round the block after switching off it wouldnt restart, i left it for 10 mins (touched nothing) tried again and vvvroomm away she go's !
    unable to check the waste gate diaphragm yet. any other ideas befoe i get it into the garage. i am not too clever with spanners !
    just a guess could it be a blocked fuel filter ?
    DAVIDP20V - 95' Polar Silver RS2 standard 315 bhp, forge diverter valve, Mark H mod and boost gauge..... and shes for sale.
  • martinjs
    • 3205
    David,
    have you checked to see if there are any fault codes stored?
    i wouldnt rule out the fuel filter, it is a pita to change on avants apperently but doesnt cost the earth so is worth doing anyway.
    HTH
    martin
    • Pisobiker
      • 1175
      Spark plugs?
      Coil packs and extensions?
      Marco
        David - You can pop into my gaff in MK for a quick look if you like. Sunday morning is good - there'll be a certain blue S2 getting a tweak as well. I can pull fault codes if you like and run some leak checks. I've some new spares if we find the gremlin to be one of the usual suspects.
        PM me if interested...
        • DAVIDP20V
          • Dec 2003
          • 165
          Mr Nugent you have mail !
